94 OBS No Start - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2013, 10:57 AM Thread Starter
94 OBS No Start
Hi guys, I need a little help to point me in the right direction. I'am new to the diesel world, but not to working on engines. I just picked up a 94 F-350 with a powerstroke and it suffers from the common " no start" condition. Prior owner said it died, put another fuel filter in it and it ran another week and died again. This is what I do know i have:
- has fuel in filter bowl
- builds about 35psi at shrader valve coming off fuel filter assembly when cranking
- Did not have oil in HPOP, but replaced LPOP and reservoir is now full
- Will run and die with a shot of WD-40
- ICP does have oily connector, but unsure if it's bad enough to keep it from starting.
- Disconnected ICP and still no start
- Has new CPS and tach does bounce
It seems like a fuel issue to me, but i'am unsure how to narrow down if it's the HPOP, IPR, ICP, or possibly the IDM?
repo94 is offline
post #2 of 4 Old 05-03-2013, 01:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Anyone close to you to let you swap idm's shortly? Good thing to keep a spare, there was a member with a mud truck who could start it the same way and his ended up being an idm
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 4 Old 05-03-2013, 03:05 PM Thread Starter
I really don't know anyone off the top of my head that has one of these trucks to swap with. A friend of mine has a salvage yard, but it will be the middle of next week before i can get out there to look for back up parts. I was planning to look for a extra one to keep on hand. Any idea what pressure i should be seeing if i hook into one of the lines from the HPOP? I think i read somewhere 400-500 psi to start, does that sound about right?
repo94 is offline
post #4 of 4 Old 05-04-2013, 02:27 PM Thread Starter
So today i went out and tried testing the HPOP. Plugged line going to passenger side head, and pulled drivers side line and installed gauge. Cranked engine for about 30 seconds multiple times and nearly no pressure. Does this mean the HPOP is bad? or should I be looking at the possibility the IPR is stuck or bad?
repo94 is offline
