OBS Burning and leaking oil? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-01-2013, 06:47 PM Thread Starter
Just finished doing head gaskets, injector cups and rosewood stage 1.5 sticks. Drove 20 miles to work seemed fine, on the way home, just before i got out of town I noticed whitish smoke, lots of it. When i got out of town and could get on it she was sluggish. Couple old farmer friends leaned me towards new turbo. Got rebuilt turbo with banks quick spool. Still got same smoke but better power level. More investigating got oil dripping from up pipes and leaking from dp/turbo connection. Power level seems close to normal. Was slightly over filled with oil before first drive, 1/8in above line now 1/8in below line, guessing bout quart of oil in 50 miles. truck ran good before operation, had oil in coolant. this was my first rebuild, followed shop book for torque and installation. any ideas?
crash94 is offline
post #2 of 5 Old 05-02-2013, 06:24 AM
sgt dave's Avatar
Quoted: 3 Post(s)
oil in coolant usually means your oil cooler needs a rebuild.
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 5 Old 05-02-2013, 08:23 AM Thread Starter
Found out about that as I got into the heads, it also looked like small leak starting outside the block.
crash94 is offline
post #4 of 5 Old 05-04-2013, 11:31 AM Thread Starter
WTF! Went to check injectors and found rocker arm laying in head, broke both bolts. What could cause that?
crash94 is offline
post #5 of 5 Old 07-24-2013, 03:55 PM Thread Starter
After some trans issues being resolved and new quick spool turbo, finally back up and running. But I've got a good amount of white smoke on start up. Before it might puff a litle on cold morning but none was noticeable in the summer. Does it take time for injectors to fully seal? Oil seemed thin when I changed it before trans issue put it in the shop. Also noticed seeping from oil pan and filter. Gonna take her for a ride tommorow see how low it gets. Pretty sure it was over filling still, oil didn't smell like desiel and no water.
crash94 is offline
