Coolant leak... - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-22-2013, 07:33 PM Thread Starter
7.3powerstroker's Avatar
Coolant leak...
So I just got my engine back in and all hooked up. Fired her up today. Seemed fine. Then went to put my exhaust tip on. Came back to front of the truck and coolant was dripping all over. It's not the oil cooler since I just rebuilt it and I can see its not coming from it. It's not the thermostat housing either. It's just coming from all around the water pump. So I'm guess I need a new one or can I just put a new gasket on. If I pull it off is there any way of checking if its bad
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #2 of 5 Old 04-22-2013, 07:47 PM
you know the answer,if it were the gasket,how good do you think the pump bearing is?or the shaft seal?go for new,to bad it still wasnt out of truck,sounds like my luck
geo1 is offline
post #3 of 5 Old 04-25-2013, 06:28 AM
southern raised's Avatar
Im having same problem on my 03, i lose about a whole thing of coolant in about a day and its all coming from the water pump so im guessing its the front cover gasket, is that what you figured out yours was?
southern raised is offline
post #4 of 5 Old 04-25-2013, 06:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
mite wanna just go ahead and replace pump as well, but obviously your gasket is bad
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 5 Old 04-26-2013, 08:34 AM Thread Starter
I'm an idiot. I was wrong. Was just tw thermostat housing. Put a new one on and a new gasket. No more leak.
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
99 Turbo and Spyder
6" Lift
37" BFG KM2's
CB Radio
Soon to come
Custom Rear Bumper
Headache Rack
rosewood stage 1's
custom tunes
