Engine stalling - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-22-2013, 10:21 AM Thread Starter
stroke'n'drive's Avatar
Engine stalling
I don't know if this is a common issue or not but recently my 96 f250 7.3 4x4 has been stalling a lot when coming to a stop and sometimes just idling. It also sometimes does like a hiccup while im driving at a constant speed and will slap the u joints. I almost feel like its a fueling problem but I don't really know so im needing some help!
stroke'n'drive is offline
post #2 of 5 Old 04-22-2013, 10:41 AM
JD3020's Avatar
Do you go to Miami University by any chance? I see that your in Middletown, and i know i've seen the truck in your avatar on campus.
My truck is doing the same thing right now with the new engine, not sure if its air in the fuel/oil that needs worked out or what. Not showing any codes, and everything seems to be reading fine.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #3 of 5 Old 04-22-2013, 10:47 AM Thread Starter
yeah I go to MUH and am in oxford all the time.
post #4 of 5 Old 04-22-2013, 10:50 AM
JD3020's Avatar
Gotcha, i'm currently going to the Middletown campus, but might be going to Oxford part time/full time next semester, had some stuff get messed up so i gotta go talk to them. Spent some time in Oxford last fall helping on their mini-baja team, but just got to busy and haven't been down since around Thanksgiving.
Have you changed your cam sensor yet? Waaay back when i first bought my truck it'd have a random hiccup, never died though. Swapped in a new CPS and it cleared up.
Jimmy
JD3020 is offline
post #5 of 5 Old 05-06-2013, 05:01 PM Thread Starter
yeah i replaced the CPS and that ended up fixing it, i appreciate it? still got a dead cylinder cause of my valve cover gaskets tho. yeah i signed a lease up in oxford next year
