Help Suspected Fuel Problem - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-21-2013, 08:55 AM Thread Starter
I recently had my 96 F-250 7.3 PSD shut off while driving down the road at 30 MPH. When it shut off, it shut off clean as if I lost electrical power (no shudder or anything). No check engine light, just battery light. I tried to recrank a couple times but it never kicked over.
After a short tow to my friends house and a couple hours of scouring the forums I'm at a loss.
Here is what I have ran through/found so far:
Fuses-No blown fuses, fuel bowl heater previously disconnected
CPS-had rpm's on the tach while cranking, also confirmed with scanner (scanner also came back with zero codes)
Fuel- Replaced fuel filter (old one seemed clean/fine)
No pressure out of shrader valve
Multiple bad (dry rot) lines-removed fuel bowl and replaced lines
Screen from fuel bowl to fuel water separator very dirty-cleaned
Fuel bowl does fill when cranking
Still no pressure at sharder valve
Backed off b-nuts heading to engine-slow drip when cranking
Oil- Oil was about a quart low-filled oil
Looked in oil well in front of motor-oil full
IDM- Removed IDM-shook it and no water present
Ensured good connection/reinstalled
After reassembling everything, trying to re-establish prime. Cranked on and off for 45 min or so. Against my better judgement shot one shot of ether down the intake. Engine tried to start. (not an ether fan, don't want this thing to become an ether baby)
If anyone can help me out with next direction or what to check please let me know. This forum has been invaluable source for the last couple years and has kept my truck running. I'm at wits end. Thanks.
koomma is offline
post #2 of 7 Old 04-21-2013, 09:11 AM Thread Starter
Oh btw stock, no chip
koomma is offline
post #3 of 7 Old 04-21-2013, 01:49 PM
fuel bowl fills,how fast or slow?how old do you think pump is?might better do a pressure check,or vacuum test on it,keep searching on the site,find what i mentioned,plus f.p.r.hope that helps
geo1 is offline
post #4 of 7 Old 04-21-2013, 05:57 PM Thread Starter
Geo,
I think the bowl fills kinda slow but I don't really have a frame of reference. As far as I know the fuel pump has never been changed. Going to look into pressure/vacuum tests. Thanks for the help.
koomma is offline
post #5 of 7 Old 04-21-2013, 06:01 PM
check everywhere on the site,ive seen both off them,pressure and vacuum test,and you need to do both cause it is a 2 system pump,good searching
geo1 is offline
post #6 of 7 Old 04-23-2013, 07:13 PM
This is my first time ever posting to any forum. I have a similar fuel problem on my 1995 powerstroke. I've learned a lot about powerstrokes trying to solve the problem. I have a pressure gauge installed in the schrader valve port and only have 8-10 psi while cranking instead of 55 psi that is desired. I've tried two new lift pumps with no improvement. I've removed, disassembled, and cleaned the fuel filter assembly. It has a pressure relief valve that I thought might be causing the problem. After cleaning it I applied air pressure to where the fuel return lines connect to the relief valve and blocked the other return line fitting and found out that the relief valve spring is set at 55psi indicating the relief valve was ok as well as my pressure gauge.
jstalter is offline
post #7 of 7 Old 04-23-2013, 07:42 PM
Sorry, my computer decided to post before I was finished. I replaced the IDM at first because it had a trouble code that would appear after clearing. I've checked the HPOP pressure also using a gauge that read 3000psi while cranking. I removed the valve covers to inspect the injector/glow plug wiring and everything appears ok. Not knowig any better I have been able to hear it run using starting fluid but only if the injector plugs are disconnected. When the injectors are connected it will not start using starting fluid. ??? I thought maybe bad fuel could be the problem so I disconnected both fuel lines near the tank, bought a new fuel can, filled it with fresh diesel, and used new fuel lines inserted in the fuel can. No change. I've stopped using starter fluid after reading the forums. I don't think that I've done any damage because the compression sounds good while cranking. It almost starts as long as the starter is cranking but will not run on its own.
At this time I still have not solved the low fuel pressure and fell that if I had the desired 55psi it would start. I haven't helped solve your problem but would like to know if you have had any luck on your own. If I do find my problem I will post my findings
jstalter is offline
