Rough Idle and Hard Shake any idea please - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-19-2013, 01:51 PM Thread Starter
97Powerstroke6in's Avatar
Exclamation Rough Idle and Hard Shake any idea please
I have a 1997 PSD and just recently it was idling real bad and shaking whole truck hard and it was only when first started and only lasted around 1-2 mins and throws a check engine code but only when its running bad goes away when smooths out was doing it for about 3 days Truck has virtually no power also during this. well today it did it upon start up and went away as normal and I got to driving around and seen some buddies..me being a jack.. and with some egging from them I took off hard from a stoplight pulled great as normal for about 70-80 feet then it started doing the rough idle and shaking so I pulled over and shut truck off and restarted it was gone... for about a quarter mile then returned, now it does it nonstop. I was just wondering ideas before I started wasting money by guessing.. I wanna say glow plugs but im not a diesel mechanic. any help is greatly appreciated, hate when my trucks down. thank you
97Powerstroke6in is offline
post #2 of 14 Old 04-19-2013, 02:01 PM
clever7.3name's Avatar
Uvch, start there
Sent from AutoGuide.com App
2000 CC F350 DRW
TW tuned
Riff Raff IAH delete
Riff Raff Hpx
Sinister Boost fooler
Wicked Wheel
6637 Intake
Muffler delete
GS 3 in 1 Diesel Gauge
CASPER, WYO
clever7.3name is offline
post #3 of 14 Old 04-19-2013, 02:08 PM Thread Starter
whats that?
post #4 of 14 Old 04-19-2013, 02:10 PM Thread Starter
oh I gotcha how do I know if its bad?
post #5 of 14 Old 04-19-2013, 04:09 PM Thread Starter
went and ran codes on it and it comes back p0171 which reads lean O2 on bank1 idk what it translates to for diesel
post #6 of 14 Old 04-19-2013, 05:44 PM
kkbodyshop's Avatar
have it scaned. that will tell you if the injectors buzz good an if there bad.
94.5 f350 dually
216k miles
straight piped
intake
fuel shim
ts chip
kkbodyshop is offline
post #7 of 14 Old 04-19-2013, 09:18 PM
A lot of times a lean code comes from an injector not operating properly. This can come from lot's of things such as the aforementioned UVCH. First place I'd look.
Haulstroker is offline
post #8 of 14 Old 04-19-2013, 09:24 PM
I have had that same symptom. It was fuel filter change time.
97 F350 7.3 super cab full bed dually
Autometer Sport Comp II boost and egt
TS 6pos tuner
Clutch clevis mod
Tymar intake
Stancor/White & Rogers GPR
Dyno test 221.5hp @ 187,000 mi. Before mods.
Other mods soon :
diamond back dp and 4in exh
ebp del ped
ccv mod
ww2.
drsmith3 is offline
post #9 of 14 Old 04-21-2013, 02:39 PM Thread Starter
what is the part that bolts to the side of the fuel filter housings and the fuel pressure regulator screws in?
post #10 of 14 Old 04-21-2013, 03:57 PM
check the u.v.c.h electric connector on that side of motor,look for burn marks or anything discolored,it is the harness heading into valvecover,also i have put 1 oz of 2 stroke oil in with every gal. of fuel,im loving it,the old gal seems to just purr now,it just helps to lube the injectors,quiets em up a bit too
geo1 is offline
Tags
glow plugs , rough idle
