EBPV Pedestal Leak FIX!!! - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-12-2013, 06:47 PM Thread Starter
gabegoforth's Avatar
Ok so after tearing my turbo of to rebuild the EBPV I figured out that all you need to do is simply adjust the rod that activates the EBPV. You might even be able to do it in the truck. I couldn't understand why it was leaking tell after I was installing the rebuild kit I had purchased. My seals were as good or better than the rebuild kit I just purchased. Well its simple over time the EBPV actuator spring relaxes and will need to be tightened up. I might be rejoicing early, but I'm pretty sure its the cure. Sorry if somebody already discussed this, but I couldn't find anybody that wasn't just deleting it.
I still have to put the Turbo back on and test it, but it just has to be the cure.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #2 of 2 Old 04-24-2013, 10:11 AM
Quoted: 3 Post(s)
Anything to report on this?
If there is a possibility that it just needs adjustment sometimes, I'd sure like to know how this could be done.
Although my EBPV is still working OK on my 96, I do use it as an exhaust brake too so would be interested in knowing how to service it in the future.
Airstreamer67 is offline
