Replaced HPOP now CEL on - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-09-2013, 06:34 PM Thread Starter
I replaced the HPOP on my 96F250 with a new 17 degree sd hpop. Truck start and sounds good. CEL light is on. When I first turn it on no CEL then 30 seconds later engine acts like I tapped the gas(rpm goes from 500 to 700 for a second) and the CEL comes on and engine goes back to normal. The engine has no power. I tried to read the codes from it but code reader is unable to connect.....
Any help would be greatly appreciated!
Thanks
Edit/Delete Message
lobograndemalo is offline
post #2 of 8 Old 04-09-2013, 07:03 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Could be many many things. ICP, IPR, UVCH, and who knows what else.
Get a good scanner.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 04-09-2013, 07:13 PM Thread Starter
Went to 2 Orielly's and 2 Autozones and none of the scanners report a code.....
post #4 of 8 Old 04-09-2013, 07:54 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Cause they can't.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 8 Old 04-09-2013, 08:21 PM Thread Starter
So their scanners can't but you want me to get a "good" one?? How does that help? If you don't have any experience with the problem please don't post.
post #6 of 8 Old 04-09-2013, 08:29 PM
gabegoforth's Avatar
Auto Engnuity or start calling shops tell you find one that has that or a Ford diagnostic scanner.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #7 of 8 Old 04-10-2013, 06:07 AM
Full A-Team Member
Fordman247365's Avatar
Check the plug connections on the IPR valve and the ICP sensor. Make sure they are plugged all the way in.
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #8 of 8 Old 04-11-2013, 04:39 AM
Jesilvas is right - their scanners will not handle the extended codes required for diesels. You are shooting in the dark unless you know which code is tripping the CEL.
F250HD 1997 4x4 PS-Diesel Crewcab, MT,
Ron's 1.00 turbo, EBPV-delete, BD downpipe, felineless, Baby Swamps, TS Performance chip, pillar pod/pyro-boost-temp, 185k miles.
rsrace is offline
