intermittent dash battery light - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-04-2013, 09:23 AM Thread Starter
Anyone know what can cause the battery light to come on then go off often as i am driving as well as idling
1997 f250hd xtra cab 4wd lb. Psd. Ccv mod, superchip.
atstew42 is offline
post #2 of 5 Old 04-04-2013, 09:38 AM
superduty4x4's Avatar
Make sure your connections at the batteries are clean and tight.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 5 Old 04-12-2013, 03:10 AM
Quoted: 3 Post(s)
I just read on here a small wire / plastic clip on top of the alternator could be loose and cause the light to alarm.Check the connection.
Airstreamer67 is offline
post #4 of 5 Old 04-15-2013, 10:49 AM
StrokinNSmokin6.0's Avatar
Its the plastic clip. Mine used to flash all the time and I finally had someone wiggle it around while I was looking at the gauges it that was the problem.
I personally cut off the clip and Soldered the wire to the prong and I have never seen the light come on since. The only draw back to doing that is if you need a new alternator you will have to cut the wire to get it off but I crimped a longer piece of wire to the factory one. Just my .02
04 F350 With all the mods.
StrokinNSmokin6.0 is offline
post #5 of 5 Old 04-18-2013, 06:39 AM Thread Starter
Thanks all. It was plastic clip on alternator. Fixed it and no more problem.
thanks again
atstew42 is offline
