Low boost/high EGT towing - Ford Powerstroke Diesel Forum
post #1 of 17 Old 03-31-2013, 01:56 PM Thread Starter
Dzldust's Avatar
1997 f350-4x4-4.10 gears-auto-285/75/16 tires
Exhaust/big air filter/Wildman chip/gauges
...now the situation I have is I just put the Wildman chip and gauges in and towed my 8k camper less than 200 miles away.while towing I noticed its easy to get to 1200 degree temps on egt gauge and only see 15-17psi max on boost gauge at shifts.truck falls on face in heavy tow or race tune.really see no difference in stock,economy or light tow tune as gas as boost/egt's or power.i see a small increase in boost in street tune.dont have an intercooler and have stock injectors.fuel issue maybe?
Dzldust is offline
post #2 of 17 Old 03-31-2013, 02:02 PM
c69ss396's Avatar
exhaust leaks on you up pipes or manifold gaskets?
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #3 of 17 Old 03-31-2013, 02:32 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You need to check for boost leaks or exhaust leaks.
For lack of power, you could be running out of fuel or high pressure oil, or both.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 17 Old 03-31-2013, 03:47 PM Thread Starter
Dzldust's Avatar
What about the high egts without really pushing the truck?
Dzldust is offline
post #5 of 17 Old 03-31-2013, 03:52 PM
c69ss396's Avatar
High egt and low boost can be tied together, If your up pipes and or manifold gaskets are leaking it will cause low boost and high egts.
c69ss396 is offline
post #6 of 17 Old 03-31-2013, 03:55 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Lack of air to complete the combustion of all the fuel allows for hotter temps.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 17 Old 03-31-2013, 03:55 PM Thread Starter
Dzldust's Avatar
Truck is stock,never been into the intake or manifolds as far as I know,any way to diagnose other than pulling it apart?buddy of mine was telling me that my fuel socks in my tanks may be clogged and restricting fuel flow.if I manually shift truck I can get 25 psi
Dzldust is offline
post #8 of 17 Old 04-01-2013, 06:12 AM Thread Starter
Dzldust's Avatar
Could the turbo be going out.truck has 196k and I have no record of the turbo being replaced.
With a manifold leak or up pipe would I hear anything like hissing or what sounds like a leak?
Dzldust is offline
post #9 of 17 Old 04-01-2013, 12:26 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Look around your engine bay for black soot around your manifolds, up pipes, and turbo
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #10 of 17 Old 04-01-2013, 01:44 PM Thread Starter
Dzldust's Avatar
found some sooty streaks under the up pipe,had to get under the truck to see it,I forgot to mention that the truck does not like heavy tow or extreme settings,starts to stumble and idle lope
Dzldust is offline
