Power Loss - Ford Powerstroke Diesel Forum
post #1 of 15 Old 03-30-2013, 04:31 PM Thread Starter
chris79bronco's Avatar
Power Loss
Not sure if Im having HPOP probs or something else, It takes off fine (up to around 1500 rpm) but after that before it shifts theres nothing there. And its intermitent, sometimes it will be like this for miles, and then I sit at a light for about 3 or 4 minutes and it got balls. its a 97, 6637 mod, 3dp and 5" to 2 6" stacks. Auto 2wd 166k. Ive done my best testing the hpop (went and bought the guage and hose) from a port in the passenger side head bud finding the correct pressures has been a no go. Cant find a definitive answer what the pressure should be at that location on the motor. Is there something im missing on this thing or is this just the way the trucks going to be till I get bigger injectors and hpop and tunes?
chris79bronco is offline
post #2 of 15 Old 03-30-2013, 04:45 PM
jesilvas's Avatar
Quoted: 3 Post(s)
What were your HPO pressures?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 15 Old 03-30-2013, 04:59 PM Thread Starter
At that port it was 600 psi at idle, didn't drive it just stabbed it couple times and shot up too 900-1000 then back down to 500-600
post #4 of 15 Old 03-31-2013, 04:26 PM Thread Starter
Still trying the search and found nothing, maybe Im not searching for the riht thing
post #5 of 15 Old 03-31-2013, 04:38 PM
jesilvas's Avatar
Quoted: 3 Post(s)
You need to see what the ICP is reading under a load when the problem occurs.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 15 Old 03-31-2013, 04:41 PM Thread Starter
how would I do that?
post #7 of 15 Old 03-31-2013, 04:45 PM
jesilvas's Avatar
Quoted: 3 Post(s)
What you were doing, just drive it and watch the gauge.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 15 Old 03-31-2013, 05:32 PM Thread Starter
Ahh, that makes sense lol. Alright I'll do it tonight and report the results in the morning. Thanks for your help
post #9 of 15 Old 03-31-2013, 06:43 PM Thread Starter
Well on the way here to work, at wot its 2500-2700, just cruising its 1000-1500
post #10 of 15 Old 04-01-2013, 03:30 AM
jesilvas's Avatar
Quoted: 3 Post(s)
That seems normal.
4R100, 2wd
330,000 + miles
jesilvas is offline
