Air in my fuel after start up.. - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-30-2013, 01:38 PM Thread Starter
jemorgan3's Avatar
Quoted: 19 Post(s)
So my efuel system is still acting up.. I turned the pump on today and crawled under the truck to find a fuel leak and it started cavitating (air in the lines at the pump) about 15-20 seconds after I turned it on. I turned it off, waited a few minutes and turned it back on and the same thing, sounds very strong for a few seconds, then air again. The fuel pressure gauge under the hood shows it holding 65is psi, but the needle dances a bit once the cavitation starts. I checked all the joints and an fittings in the system and no leaks, could this be an in tank problem or... gulp... a problem at the injectors letting air in? I really hope its not the latter, but I dont see how air entering the system AFTER the pump can cause cavitation at the pump. soo lost here
jemorgan3 is offline
post #2 of 8 Old 03-30-2013, 02:13 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I don't see air getting in at the injectors.
I'd think an in tank issue or maybe at your selector valve.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 03-30-2013, 03:09 PM Thread Starter
jemorgan3's Avatar
Quoted: 19 Post(s)
if the breech were outside the tank, wouldnt there be a fuel leak at the same spot? What should I be looking for if I go inside the tanks?
2005 CCSB F250 FX4
Studs, New H/G, Blue Spring Mod, PHP 40 HP Atlas tune and 80 HP Heavy Tow tunes, and a new turbo.
post #4 of 8 Old 03-30-2013, 03:44 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I'm not entirely sure on the OBS pickup assemblies, but for SD 7.3s and 6.0s, they would crack and let air in when the tank got low on fuel.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 8 Old 03-30-2013, 06:51 PM
PowerstrokinIt F250's Avatar
there should be a screen on the end of the pickup tube inside the tank they are known to break
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #6 of 8 Old 03-31-2013, 11:45 AM
I have had the tank pickup fall off (common problem with the pickups on these trucks) which caused the truck to suck air when the tank still showed 1/2 full. But I'd expect the cavitation would go away when you switched tanks (unless they both had fallen off?) or if you fill the tank full...where they break is somewhere around 1/2 full if I recall right.
F250HD 1997 4x4 PS-Diesel Crewcab, MT,
Ron's 1.00 turbo, EBPV-delete, BD downpipe, felineless, Baby Swamps, TS Performance chip, pillar pod/pyro-boost-temp, 185k miles.
rsrace is offline
post #7 of 8 Old 04-10-2013, 02:17 PM Thread Starter
jemorgan3's Avatar
Quoted: 19 Post(s)
my problem is with both tanks no matter where the fuel level is, you can hear it start sucking air after about 10 seconds of the pump being on, engine running or not. Actually got stranded on the highway last weekend, lucky enough I coasted down an off ramp and into an autozone parking lot when the fuel pump gave out!!
2005 CCSB F250 FX4
post #8 of 8 Old 04-11-2013, 03:35 AM
Is there a way you can split the problem? for example, could you rig up a system to run a hose from a bucket of clean diesel to the pump in order to prove that your pump and system forward is working (it should run fine "out of the bucket"). If it still sucks air, you know your lines, selector switch and tanks are not the issue (and vice versa). I know it takes a little "doing" to wire up something temporary like this...but it seems the only other way is to tear into the tanks and selector switch strategically.
rsrace is offline
