7.3 Not starting when cold - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-30-2013, 07:00 AM Thread Starter
Hey guys I just recently bought a 95 f350 7.3L with a 113k on it. This is my first diesel and Im having a problem. In the mornings when I go out to start it up it wont start unless I shoot a little starter fluid into it. Now from what Ive read this is very bad for it. I only have to do this in the morning and the rest of the day it will be good. Any ideas on what this could be any help is greatly appreciated!
Thanks Mark
9739340276
markcrevina is offline
post #2 of 5 Old 03-30-2013, 07:46 PM
PowerstrokinIt F250's Avatar
use your block heater, replace your glow plugs and glow plug relay. DONT USE STARTER FLUID
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #3 of 5 Old 04-02-2013, 12:00 PM
if i could jump in with the same question...1995 7.3 i have to keep her plugged in to cold start but i just put in GPs and GPR and she still wont start up cold unless plugged in i hear a lot about injectors i haven't put them on a scan tool (havent had the time to take it somewhere) but the truck drives fine im not sure how it can drive this well while they aren't functioning correctly if that is the case but i also i heard talk of crank case pressure being low in my case could be an issue and how to check and correct that if needed
bnick42 is offline
post #4 of 5 Old 04-02-2013, 05:44 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Just keep it plugged in, Mines the same way. It wont start unless its plugged in. I plug mine in every night, along with the 6.0...
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #5 of 5 Old 04-02-2013, 05:56 PM
kylev90's Avatar
Quoted: 4 Post(s)
if you replaced glow plugs and relay but are still having issues next step is under valve cover harnesses. could have bad wiring not allowing power to glow plugs.
1997 CC SB. Stage 1s, 17*hpop, S&B CAI. 4" straight pipe, TW tunes, zf5 swap
kylev90 is offline
