same crap different day - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-29-2013, 05:51 PM Thread Starter
In January after drivin about 3-4 miles down the interstate i got on an off ramp while sitting at the stop light my truck died like you turned the key. after 30 minutes of cranking it started and ran fine. after some research i replaced the cps. well this seemed to fix the problem. today after driving 1- 1.5 miles on the interstate it did the same on the offramp it started after about 5 minutes of cranking. it threw the same code i think it was 0344 reading something about cps circuit a i think.. if you have any idea what could be causing this please help thanks sorry bout the long post
deerslayer42694 is offline
post #2 of 6 Old 03-29-2013, 06:03 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Could still be the CPS or maybe even the harness to it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 03-29-2013, 11:15 PM Thread Starter
which cps should i get if that is the problem? ford oem, alliant, international?
post #4 of 6 Old 03-30-2013, 08:01 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Black, Grey, & Dark Blue Cam Position Sensor Perdels Test - Diesel Forum - TheDieselStop.com
Hopefully that answers your question.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 6 Old 03-30-2013, 11:09 AM Thread Starter
i unplugged the cps and there was oil in the plug part of the wire not the sensor could this shorted the sensor enough to throw a code and shut the truck down?
post #6 of 6 Old 03-30-2013, 03:05 PM
jesilvas's Avatar
Quoted: 2 Post(s)
There sure shouldn't be oil in there. Get some di-electric grease after cleaning it out.
4R100, 2wd
330,000 + miles
jesilvas is offline
