big *** oil leak 96 powerstroke. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-27-2013, 10:22 AM Thread Starter
quicknick106z's Avatar
Angry big *** oil leak 96 powerstroke.
big OIL LEAK. coming from the driver side and its got to stop please help.?????:help :
96 ford f250 7.3 edge evo straight pipe (Blown up Junk
quicknick106z is offline
post #2 of 6 Old 03-27-2013, 11:59 AM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
It could be a few things. There are large plugs for the High Pressure Oil System on BOTH ENDS of EACH head. They are about 2" in diameter with a 1/2" square-drive recess. Check those out. The oil cooler can leak as well from the cooler-to-header joints (either end) as well as the header-to-block joints (front and rear adapters). Also check the engine valley to make sure it's not coming from up there. Post back any findings if you are still unsure. Cheers!
Patrick Feeley is offline
post #3 of 6 Old 03-29-2013, 11:07 AM Thread Starter
this thing is bad i think its coming from the steel line's but how the hell do you get to it
post #4 of 6 Old 03-29-2013, 11:17 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Very well documented problems the oil leaks are.
You need a tool to pop off the lines.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 6 Old 03-30-2013, 08:22 PM
Quoted: 8 Post(s)
The braided steel flex lines from the HPOP to the Heads? If so, no special tool needed to pop off the lines (that was an SD thing). Cheers!
post #6 of 6 Old 04-23-2013, 02:16 PM
Blazin8556's Avatar
My cooler just in front of my oil filter can leave a nice puddle under the truck
1995 F350 XLT|DRW|7.3L Powerstroke|1.0 turbo|3" Diamond Eye Downpipe|Straight Piped|EBPV delete|DIY 6637|RiffRaff turbo inlet boot|203* thermostat|IDM mod|CCV|Built E4OD|Derale Trans Pan|Trans Temp Gauge|Explorer RAP RKE. Traded for a chevy
2007 F350 Lariat 6.0 . under the knife already
Blazin8556 is offline
