Fuel Leak - Ford Powerstroke Diesel Forum
post #1 of 7 Old 03-24-2013, 12:21 PM Thread Starter
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Fuel Leak
Leaking right underneath the fly wheel, Very slow leak. Nothing major. Wonderin if any of you have had the same issue, if so what was it.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #2 of 7 Old 03-24-2013, 06:16 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
First, look in the engine valley for fuel puddling. There is a drain path from the valley down the passenger rear of the engine (and onto the inspection cover). Of course there are lots of things to leak in the valley:
Fuel pump out the weep hole on the base
Fuel pump banjo bolt
Fuel bowl (it can rot out at the bottom)
Fuel bowl lid
Fuel bowl-to-pump hoses
Fuel Pressure Regulator-to-bowl joint
Fuel Restriction Sensor (very common leaker, you can use a 1/8 NPT plug instead)
Water-in-Fuel sensor (not common)
Fuel heater feedthrough (not common)
If there is nothing in the valley, look at the fitting on the rear of the heads as there are seals there that can go bad. Cheers!
Patrick Feeley is offline
post #3 of 7 Old 03-24-2013, 08:03 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
There are also a few fuel lines that are very prone to leaking and dry rotting out
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 03-25-2013, 05:41 AM Thread Starter
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Awesome! Thanks guys, ill take a look!
Tom
Other Rides
tkobes43 is offline
post #5 of 7 Old 03-30-2013, 12:18 PM
do you guys know of a write up for removing the fuel bowl? can't seem to find one (1995) it looks simple but ive only removed the pump before any help or advice would be appreciated !!!
bnick42 is offline
post #6 of 7 Old 04-04-2013, 06:39 AM
Jmiller02's Avatar
DIAGNOSE YOUR FUEL LEAK!!! READ 4 INFO!!
This is a sticky at the top 1 page back...
2013 F350 6.7 CCLB KR 4X4. No Limit Intake. 4" delete pipe. No Limit Blockoff Plates. SCT Livewire TS. Leveled. 35" shoes.
FOR SALE 2002 F250 7.3 psd crewcab short bed. 4x4. DIY 6637. 4" turbo back mbrp exhaust. PHP Hydra. AIH Delete. Riff Raff CCV Mod. New icp. New cps. New ebps. Rebuilt ipr. 207,000 miles. 4" rough country lift. 05' front end. Driven diesel pre pump kit. Shimmed fpr. Boost guage. Fuel pressure guage. Tranny temp guage. EGT guage. FOR SALE
Jmiller02 is offline
post #7 of 7 Old 04-04-2013, 09:46 PM
thanks so much!
bnick42 is offline
