homemade tool,worth it or not? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-23-2013, 05:38 PM Thread Starter
I have searched,cant find an equivelent,say you took a operating injector,wired it properly to hook into uvch harness,do you think that is the most econimical way to go to test i.d.m.,im thinking for on the road,my 350 is a dump truck,no one in my area will tow me loaded,a ways away,yes there is the trucks,any thoughts out there,thanks
geo1 is offline
post #2 of 5 Old 03-23-2013, 08:28 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I'm having difficulty envisioning what you are trying to do. The most economical thing in my mind is to find a cheap (and good) IDM on ebay and carry a spare you can swap in. I have 2 of them that I got for $50 each. Cheers!
Patrick Feeley is offline
post #3 of 5 Old 03-24-2013, 05:52 AM Thread Starter
Thanks for the reply,new to powerstroke,read thru a lot of old threads,seemed like a lot of idm issues,didnt know if i should treat it like a wear item or not,never thought about ebay,thanks again,geo
geo1 is offline
post #4 of 5 Old 03-24-2013, 06:19 AM
jesilvas's Avatar
Quoted: 2 Post(s)
I'm at 334k miles on original IDM, so it's not a wear part.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 5 Old 03-24-2013, 08:54 AM
Quoted: 13 Post(s)
Yeah, its not a wear item, but they can go bad (electrical part failure or sometimes water intrusion). If all the valvecover wiring harness connection inspections and checks are good, sometimes the easiest thing to do is swap in a known good unit. Cheers!
