Low idle. How to adjust ?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-17-2013, 05:25 PM Thread Starter
Dirt rider1's Avatar
I've got a 97 7.3 and its idling kinda low. How do I adjust the idle??
Jordan
Jordan
(dirt rider1)
1997 7.3 Powerstroke 2wd auto
Mods:
-Muffler cut off
-Cat. converter gutted and gone
-Diamond Eye 3" downpipe
-MBRP 4" exhaust (runs in front of rear wheel)
-Dodge Towing mirrors
-AFE high flow intake
-Real Tree seat covers
-Real Tree floor mats
-blacked-out headlights
-cab lights
-6 by 8' flatbed
-KC lights
-silencer ring removed
-17ton anchor shackle
Dirt rider1 is offline
post #2 of 9 Old 03-17-2013, 06:46 PM
JD3020's Avatar
You don't. Its a fully electronic controlled engine, so the idle is completely controlled by the PCM. You can have tunes written for it though, and have the idle changed.
Why do you think the idle is too low?
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #3 of 9 Old 03-18-2013, 07:12 AM Thread Starter
Compared to my friends 97 cummins it seems to idle low
Jordan
(dirt rider1)
Mods:
-Muffler cut off
-cab lights
-6 by 8' flatbed
-KC lights
post #4 of 9 Old 03-18-2013, 08:55 AM
JD3020's Avatar
Your friends Cummins also has 2 less cylinders, and they are all in a row. So don't compare how his truck runs, to how yours runs.
What is your 7.3 idling at right now?
Jimmy
JD3020 is offline
post #5 of 9 Old 03-19-2013, 08:16 AM Thread Starter
About 600rpm
Jordan
(dirt rider1)
Mods:
-Muffler cut off
-cab lights
-6 by 8' flatbed
-KC lights
post #6 of 9 Old 03-19-2013, 08:25 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
That's about where it's supposed to
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 9 Old 03-19-2013, 08:32 AM
gabegoforth's Avatar
Thats right on the money. The Cummins is totally different. I think my dads idles at 800rpm. Which is why if anything the Cummins should come down 200rpm. I personally think they idle a little high, but hey it works. lol Our Combine idles at about 875-900. It has a Alis-Chalmers 3500 Turbo I think. Its like 7.9 liters(maybe even 8.2), and it only produces 140-200hp. Our John Deere C-450 idles at about 600-700rpm. It's a 4-cyl though.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #8 of 9 Old 03-19-2013, 08:35 AM
Powerstrokes Say right on the motor what there supposed to idle at. Its on the valve cover behind the alternator and oil fill spot.
post #9 of 9 Old 03-19-2013, 06:11 PM Thread Starter
K thanks y'all
Jordan
(dirt rider1)
Mods:
-Muffler cut off
-cab lights
-6 by 8' flatbed
-KC lights
