Have stripped threads on Output of HPOP - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-14-2013, 04:08 AM Thread Starter
Recently completed work on HPOP and thought the threads were a little weak on one of the outputs of the HPOP. Started up the truck ran fine while idling. Shut truck off came back to start, wouldn't start. Looked under hood HPOP and the read connector had bee blown out of the HPOP with the aluminum threads on the hose connector.
Two options replace the HPOP or try to repair the threads with a Helicoil, any thoughts?
ksu_cowboy is offline
post #2 of 3 Old 05-07-2013, 10:44 PM
My truck has done the same thing, just today and im wondering if you have fixed it or did u just get another pump...
butter7.3 is offline
post #3 of 3 Old 05-08-2013, 03:49 PM
FWIW, with the pressures these things are capable of (3000 PSI!), I'd do a new HPOP rather than a helicoil.
Haulstroker is offline
