1995 7.3 5spd CC Oil Leak. Help!!! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-13-2013, 04:20 PM Thread Starter
gabegoforth's Avatar
I have two oil leaks. One off the oil filter, and the other off the Starter. I have just rebuilt the oil cooler hoping that would cure the leak on that side. I did put a new filter on it. It was leaking like this before I attempted to fix it. It a good sized leak because it leaves 3" spots on the asphalt in about 2 minutes. Any ideas would be greatly appreciated.
1996 F-350 Crew Cab 4x4, Auto, Toyo MT 315/65/16r, full force 160/30% injectors, Super Duty electric fuel system, RiffRaff regulated return, Driven diesel electric fuel pump controller, SWAMPS HVHF IDM, custom tuned TS chip, 1.0 Turbo, CX Intercooler, 4" Exhaust, 6637 Intake, 4.10 Gears, 225k+ miles.
gabegoforth is offline
post #2 of 8 Old 03-13-2013, 07:46 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Check all the High Pressure Oil Rail End Plugs. They are located on each end of each head (so 4 per motor) and are about 2" in diameter with a 1/2" square-drive recess. They like to leak. Cheers!
Patrick Feeley is offline
post #3 of 8 Old 03-13-2013, 10:01 PM Thread Starter
So it would be my back ones? I thought those were fuel lines back there. Hows the best way to look at them? Could they cause the truck to not run that great?
Thanks. I have learned more about 7.3s in the last month than in a year of owning one. There is so much that should be maintained that no body talks about. The EBPS being the biggest one. I thought that sensor was a oil pressure sensor till I was advised to clean it out. Never had fallowed the line down.
post #4 of 8 Old 03-15-2013, 11:45 AM
Quoted: 15 Post(s)
Rear ones you can see with a mirror (actually just a good flashlight from under the truck. Front's might be more difficult (I can't remember but you mat need to unbolt the accessories on the front). Cheers!
post #5 of 8 Old 03-16-2013, 09:49 PM Thread Starter
Located them. The back pass is bad. Is it just a o-ring? Still doesn't explain the drivers side coming down on top of the oil filter, but the last time i moved it it looked liked it had quit. Do gaskets some times take time to set up? Although the oil pan gasket looked like it could be replaced too.
post #6 of 8 Old 03-17-2013, 08:03 AM
Quoted: 15 Post(s)
The plug has an integrated o-ring:
Oil Rail End Plugs (large plugs at each end of heads; incl. O-rings, use LOCTITE #11747 to seal threads)
(Ford) Same number as International
(International) 1827535C94
The oil pan uses the special Wacker RTV to seal it and the engine has to come out to reseal it. Cheers!
post #7 of 8 Old 03-17-2013, 08:33 AM
JJFLASH's Avatar
Quoted: 111 Post(s)
If you have oil coming down the driver's side that is collecting on the filter I would check your CCV. It's sealed to the valve cover with a couple big fat o-rings that tend to swell then push out and leak oil all over. Mine has been doing it for a while. I have a kit from Ford just haven't gotten around to it yet. Kit's cheap...don't remember how much exactly though.
And hello there Patrick!
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #8 of 8 Old 03-17-2013, 09:58 AM Thread Starter
Well the engine is staying put. lol Maybe next fall I'll look into if I have nothing better to do. lol Ok I'll look into the oil leaks that I can get to.
