HPOP reservoir leak - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-11-2013, 03:03 PM Thread Starter
Angry HPOP reservoir leak
I am having trouble with an oil leak at the HPOP reservoir. The leak is on the low pressure side of the reservoir. We have replaced the gasket six or seven times and it cures the leak for a short time unless you have to start the engine when its cold and hasn't been plugged in, then it will leak until the engine warms up. I have replaced the IPR and the IPC sensor before I noticed the leak seems to be coming from the low pressure side. I also took the reservoir in and had the mating surface machined to make sure it wasn't warped. When the truck is running and not leaking oil it runs very good and has good oil pressure. It also carries good oil pressure when it is leaking
nobull is offline
post #2 of 2 Old 03-11-2013, 03:10 PM Thread Starter
Sorry forgot to mention this engine is in a 95 F Super Duty and we have been fighting this problem since we replaced the engine with a rebuilt engine in 2007
nobull is offline
