Early 95 stopped running - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-09-2013, 02:35 PM Thread Starter
russtay's Avatar
I'm driving down the road when my truck acts like someone turned the key off, my gauges are flat lined, I tried to restart it but all it would do is crank, I towed it home and it sat for a day before I tried again, it started but only ran for about 10 seconds before it died and hasn't started sense, that was a week and a half ago, I have changed the IPR, the ICP and CPS, I pulled and shook the IDM but it made no noise, I checked all the under hood fuses twice and they are all good, I drained the fuel out of the bowl and it refilled upon cranking the motor, I checked the filter and screen on the fuel presser regulator, I have white smoke coming out of the tail pipe while cranking and the tach goes up, it doesn't bounce but does go up a little, not sure what to do next
russtay is offline
post #2 of 11 Old 03-09-2013, 02:41 PM Thread Starter
russtay's Avatar
Re: Early 95 stopped running
Oh and it hasn't had any chips installed
russtay is offline
post #3 of 11 Old 03-10-2013, 09:21 AM Thread Starter
russtay's Avatar
Anyone have another suggestion?
russtay is offline
post #4 of 11 Old 03-10-2013, 09:27 AM
66Bronco's Avatar
Check your hpop pressure on startup. Being that it's an early '95, I'm assuming that it has at least 200k miles and you've replaced everything in the oil side of the injection system other than that. You should be seeing 2800-3000 psi on cranking. Also, when you pull the test plug out of the top of the hpop reservoir make sure it's got oil in it. Your check valve may not be sealing which will allow the oil to drain back into the oil pan. Lastly, DO NOT crank the truck without the plug or a pressure gauge in the reservoir; you'll shoot oil EVERYWHERE. Hope this gets you going.
'95 F-250HD
ZF 5-Speed 13'' clutch w/ SMF conversion
B&W Gooseneck
Custom Spare Tire Mount
66Bronco is offline
post #5 of 11 Old 03-10-2013, 09:41 AM Thread Starter
russtay's Avatar
Have 151 thousand on it, I checked the level and its full, I'm trying to track down a pressure gauge that will read that high and trying to get ahold of a diagnostic scanner also, both of which seem to be hard to come by without taking the truck to a shop
russtay is offline
post #6 of 11 Old 03-10-2013, 04:30 PM Thread Starter
russtay's Avatar
I built my own oil pressure tester and cranked the motor for about 45 seconds and the needle never moved
russtay is offline
post #7 of 11 Old 03-10-2013, 06:42 PM
Quoted: 48 Post(s)
Where'd you hook it up? Either the lube oil pump (aka LPOP) is shot, or there's something with the passage between it and the HPOP reservoir.
madpogue is offline
post #8 of 11 Old 03-10-2013, 07:12 PM Thread Starter
russtay's Avatar
Ya I think I hooked it up to the wrong port, I have to get an adapter that will fit the correct port, I felt pretty stupid after I realized what I did
russtay is offline
post #9 of 11 Old 03-16-2013, 07:19 AM Thread Starter
russtay's Avatar
So the second IPR was bad, I threw in my old one and the truck started up, its running rough but its drivable till the replacement ipr shows up
russtay is offline
post #10 of 11 Old 03-19-2013, 06:41 PM
I'm having trouble with my truck not starting. I have power at the IPR but maybe that is my issue- the valve inside not working. I have oil in HPOP, lots of fuel out of the schrader.
fasteddy88 is offline
