batteries - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-09-2013, 10:46 AM Thread Starter
tshideler's Avatar
batteries
my truck turns over but would not start so I towed it to the mechanics who said the batteries were needing to go. it cranks but needs a boost jump to start from the charger to start. the mechanic said it needs a little more voltage to crank it to get the oil presure up at the injecters to allow the injecters to work. I have never heard of this before but could be? anyone have this problem or am i getting the runaround? I cleaned my cable ends and have it on charge for now as I cant afford new batteries right now as I havent been able to work due to fighting cancer so all info is greatly appriciated, Thanks Tom S.
Old age isn't for sissies
tshideler is offline
post #2 of 8 Old 03-09-2013, 10:48 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Possibly. You need a lot of power to overcome diesel compression.
If you will get the batteries load tested, and they come up bad, you probably need new ones.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 03-10-2013, 06:43 PM
dazed01's Avatar
If a car comes in with issues and I know it has a bad battery that is what I will replace prior to checking out any other issues. A faulty battery can cause quite a few problems.
Gun control is like trying to reduce drunk driving by making it tougher for sober people to own cars.
dazed01 is offline
post #4 of 8 Old 03-11-2013, 11:06 AM
Yeah, unfortunately I have heard that before. These injectors require a lot of power to even attempt to start. Just because you can spin it doesn't mean its spinning fast enough for the injectors to fire. Chances are if it starts with a booster pack, then with new batterys will fix the issue.
Have someone toss your battery on a load tester just to be sure.
1997 F250 7.3 5 speed, 3.55s, D60, 4" Diamond Eye Exhaust, Napa Intake Filter, E-Fuel, 35" bfg mt's, stage 2 rosewoods/tuning, Gauges
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
--Henry Ford
csdwarf11 is offline
post #5 of 8 Old 03-11-2013, 11:20 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Yes the injectors use the pressure the hpop builds to pressurize the upper cavity of the injector which then transfers the high oil pressure to the lower fuel cavity via a small piston to the tune of about 26000 psi so you need a lot of umpf to get the pressure that high
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 8 Old 03-11-2013, 11:39 AM
goodoleboy45's Avatar
I just went through the same issues and i changed both battiers. What a diffrence it made in how much better it runs.
2006 F350 CCLB :grd
4 in MBRP turbo back stainless/ 5in chrome tip/ DAYSTAR leveling kit
SINISTER EGR delete/ SINISTER coolant filter/ ELC coolant
Blue Spring upgrade/ 6.4 Bandjo Bolts/ Metal intake tub/ SCT livewire (Vivian's Looney Tune)
35x12.50x18 Toyo Opean Country ATII/ Recon smoked cab lights
NEXT
Sinister Engine bling
Upgrade standpipe/dummy plugs
SEMPER FI
goodoleboy45 is offline
post #7 of 8 Old 03-11-2013, 01:09 PM
7.3powerstroker's Avatar
batteries
Yeah same thing happened to my truck. But i ended up having to do injector o rings also.
Sent from AutoGuide.com App
Shelby
1995 F350 7.3l
5 speed
240,000km
DIY Intake
3.5"dp to 5" straight pipe
99 Turbo and Spyder
6" Lift
37" BFG KM2's
Harley Davidson Leather buckets
Grant Steering Wheel
Autometer Gauges Pryo,Boost
CB Radio
Custom Bumper(built it myself)
Clear Headlights (black background)
Black Grille and Headlight Trim
Soon to come
Custom Rear Bumper
Headache Rack
6.0l intercooler (already have one just need to pipe it)
rosewood stage 1's
custom tunes
7.3powerstroker is offline
post #8 of 8 Old 03-11-2013, 01:15 PM
i had the same problem, two optima batteries that were 8 months old. Had them load tested and both failed, one put out 200 cranking amps and one put out 8. I knew something had to kill these batteries so i tested the alternator. It was bad also, I did all the work myself and only spent $330. Now she cranks so easy, its a world of difference.
03blackpowerstroke is offline
