UVC Gaskets - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-05-2013, 06:11 PM Thread Starter
Send a message via AIM to mpdxtreme
UVC Gaskets
Since my electrical thermal event last night I am going to have to replace the UVC gasket. The diesel place here local has Doorman(?) are they any good? or should I order International parts? I really want to suport a sponsor so Im open to suggestions
Thanks
Greg G
1996 Ext Cab F250 PSD with 176xxx miles and climbing. MBRP 3 in downpipe into 4 in exhaust, EBPV deleted, AFE intake
mpdxtreme is offline
post #2 of 8 Old 03-06-2013, 12:45 PM
Patrick Feeley's Avatar
Quoted: 9 Post(s)
A couple of the issues I've heard of with the Dorman kits is some mis-pinned UVCH's (wires in wrong positions) and one guy had continuity issues with the gasket when torqued down (good connection untorqued and bad when torqued). I used the Dorman kit on my 94 with no issues, but I prefer the factory stuff (Ford/IH). Cheers!
Patrick Feeley is offline
post #3 of 8 Old 03-07-2013, 08:31 PM
psdstrkD95's Avatar
I dont know what a thermal electrical necesarily is. If its when the uvch burns and kills your injectors then i jsut replac e the same thing. Grabbed the parts from NAPA had to cut out the old males and splice in new ones hooked it all up running fine for a old powerstroke. But thats the only generic auto parts store i coud find that part.
psdstrkD95 is offline
post #4 of 8 Old 03-07-2013, 08:33 PM
creekfreak's Avatar
I think dormans are what most of us are running on.
Chad
95 ECLB 4x4
Rebuilt e4od
320k kilometers (Canadian truck)
BHAF DIY mod
Cat/muffler delete
Diamond Eye 3" downpipe
Western pro-plus plow on an ultra mount
Running Goodyear Dura-tracks on stock rims.
If you're wondering about the handle... Creekfreak... I paddle hard, steep, whitewater. It's been my online handle for about 15 years.
creekfreak is offline
post #5 of 8 Old 03-07-2013, 09:54 PM
psdstrkD95's Avatar
Yea i googled it and they looked EXACTLY like the ones i bought from napa probably the supplier of napa. my B.
post #6 of 8 Old 03-07-2013, 10:33 PM
kevindwatts's Avatar
I put them in mine just the other month and no issues, so I can't complain, but I haven't put many miles on it since.
Kevin
96 F350 7.3L CC SRW 4x4 PSD
Automatic, 4.10 gears
263,000 miles
NW Washington
6637 DIY Filter
BB Mod
Swamps IDM
3" downpipe and 4" AFE straight pipe (with muffler)
TS 6pos chip
EBPV wired to a switch
Kenwood Stereo System with 10"sub
Pyle Alarm System
kevindwatts is offline
post #7 of 8 Old 03-07-2013, 10:41 PM
psdstrkD95's Avatar
hey speaking of all that when i spliced into the original wiring harness there was a cable weaving in between the injector/glow plug wires under the aluminum shielding strip stuff. What is that cable for?
post #8 of 8 Old 03-07-2013, 11:18 PM
It is a ground wire for the high voltage, just unwrap it, splice all the wires together, rewrap the cable and go on about business.
Kevin
263,000 miles
NW Washington
6637 DIY Filter
BB Mod
Swamps IDM
TS 6pos chip
Pyle Alarm System
