1997 Layed down on me.
Ok guys,
I have a 1997 F-3450 RCLB with a 5spd 4x4 with 279k miles on it. When I first got it, it was sluggish, but ran fine. Changed EBPS with a new ford OEM one and cleaned tube. After that ran fine, but I did not think it was up to its potential. But the injectors and HPOP are stock, so whatever. Bought a Edge CS for gauges, truck is not tuned, and all parameters seem to be normal, other than I have low boost, and ebps sticks around 1-3 no matter what. Fast forward to today. I drive to town and leaving story, my 2-3 shift there was a slight hesitation in throttle, but it was so quick I thought that I imagined it. Away I went. about 3 miles down the road cruising at 55 it sounds like my motor turned off and CEL pops up. It got real quiet and I started losing speed. Coast 70 yards to driveway and pulled off. Entire time I still had steering and brakes, and when I came to a stop the motor was idling like normal. I get out and do a quick visual inspection and pop the hood. Nothing abnormal. Get in the truck and rev it up to 1200 a few times and nice and normal. Put my foot in it and it goes nicely to 2200 RPM and stops. No hesitation or stutter or bucking. Just a nice flow through rpms to 2200 and then stops increasing. It felt like it was designed to do that. White/Blue smoke from tailpipe. Decide to turn it off, and restart and evaluate. Cranks back up with No CEL and give her a rev and away she goes to 3200 RPM and I let my foot off. 3 miles from home so I take it home, and damn if it dont feel like it has the balls I thought it should. Runs through RPMS ranges like a champ. Get home and drive it around with no CEL. Naturally, my Edge CS is on the a new truck I just got over the weekend as I needed to pull some codes, so I wasnt able to read any data while this happened or pull the code. I will be putting Edge on in 5 minutes to see if it stored the code and will report back. Just looking for insight. While I am here, I am thinking that perhaps when I fixed the EBPS and tube, that the EBPV never fully opened. Then today while coming home it for some reason shut on me and got stuck there causing the truck to lay down. When I restarted it decided to fully open, as it should since truck was at operating temp, and that is why it is running better. Am I far off in left field with this theory? Also, outside temp here in florida was around 52 at the time of incident. Thanks. Sorry so long. This is my DD.
This things is definately running better than before the CEL was thrown. Here i will try and add some screen shots of cs...
Sent from AutoGuide.com Free App |
First code is a faulty EBPS signal. The other is faulty IPR signal. Both of these senders are really close to each other so look at the wiring between the two for damage (maybe mouse). With the EBPS sending bad or no signal to the PCM the PCM freaks out and will start opening and closing the EBPV to try and get a change in signal from the sender. When you cleaned the EBPS tube a while back did you shove a rod back into the port that the tube spins on to on the manifold? That can soot up too causing no change at the sender.
No. I did not mess with manifold adapter. Didnt want to shove anything in there. Thing is, once its been restarted it is running absolutely better than it ever has. Like i thought i should months ago after i cleaned ebps and tube. Ive had a few of these and this has been the doggiest one yet. Now it is running great. Cleared codes and have not returned.
For ****s and giggles get a new rubber hose for the MAP sensor.
Looking at your IPR % kinda scares me too. I'm assuming that these readings are in your driveway and not on the road. If this is in your driveway your IPR is reporting that it is using half of its ability to maintain pressure with no load on the motor.
Yes in driveway. Before this happened. Cruising at 2000 rpms my ipr was 18-20. Depending on hills and stuff. Icp would be between 800-1100 again depending on hills and stuff.
