changed head gasket and still white smoke - Ford Powerstroke Diesel Forum
Old 02-22-2013, 05:34 PM
so im new to this site but anyway, i picked up a 97 7.3 for a 1000 bucks and i was told it had a bad head gasket, i mean i new it was bc there was coolant in the oil and he said that it was bad so i took it home and tore down the motor and i seen there was a new head gasket on passanger side so i just replaced both of them and clean and reused the headbolts, btw the headbolts looked perfectly fine and i cleand them and put a little oil on the threads and way, i got the motor back together and started it up, and it runs perfectly fine but it still blows white smoke, it starts pretty good, but the oil is starting to get creamy.
could it be the old nasty oil that was in the hpop. im thinking its either somthing with the injectors or a bad oil cooler, but i am going to do a pressure check on it.
i just dont understand it runs perfectly fine the oil temp doest go above what its suppose to, and it starts fine
plzzzz help me im drawing a blank lol
Old 02-22-2013, 06:06 PM
So, the oil is getting "creamy"? As in chocolate milkshake colored creamy?
If that's so and you are 1,000% that there is no possible way the new head gaskets could now be leaking, sounds like a few really good possibilities.
Did you check the heads and the block for flatness using a straight edge and feeler gauges? If they aren't flat flat flat, you will get leaks no matter what else you might try. If the engine got really hot it can and does warp heads and blocks.
Did you check the heads for cracks? The only 100% way to do this is Magnafluxing and typically requires a machine shop that is equipped.
Check out your oil cooler too.
The block could have a crack also.
Old 02-22-2013, 06:12 PM
yea the oil is starting to get the milkshake color again but, i didnt change the hpop oil so i kinda think the oil that was in it mixed with the new oil
i had the head checked and the block and everything look perfectly fine, i cleand everything perfectly i mean it was totally flat clean surface, i carbon scraped everything
i also got the torque procedure off of shopkey 5 the snapon database, and i did it with a snapon heavy duty torque wrench.
theres no oil or anything in the coolant just looks like the coolant is still in the oil
is there anyway to completly flush the oil system
Old 02-22-2013, 06:46 PM
Only way I know is to drain every last bit you can, including the HPOP, use a new filter. You'll have to just change it all three or maybe four times. The problem is that there is oil all through the engine that doesn't get changed when you drain the crankcase. Lifters, the entire High Pressure Oil system including what's in the heads and the injectors, the oil cooler, puddled under the valve covers, etc. The only way to get that out is to rinse it clean with fresh oil.
Seriously sucks and gets expensive. Seems like there should be a better way, maybe by tapping into the Low Pressure system where a gauge would connect and forcing pressurized oil through the engine. Car Craft magazine built a pressurizer system like that for about $30 bucks as I remember. The article should be on their site. Carcraft.com
If you figure out how to do this, I'd have it draw from clean oil only and leave the drain plug out, draining into a separate container. Still gonna use 30+ quarts of oil at a minimum.
Old 02-22-2013, 06:49 PM
yea i hear ya, the plus side is i can get all my oil free so i dont have to worry about that just gotta get a couple oil filters
once i flush the system then ill really know if that was the problem, but im gonna pressure test the cooling system too to be safe
id rather it be anything but head gaskets lol that turbo pisses me off
Old 02-22-2013, 06:59 PM
what about freeze plugs would that cause anything to mess up
Old 02-23-2013, 10:10 AM
Just a loss of coolant.
Old 05-08-2013, 07:36 AM
injector cups could be leaking that will put water in the oil
