Water in Fuel - Ford Powerstroke Diesel Forum
post #1 of 2 Old 02-04-2013, 06:29 AM Thread Starter
tblg700's Avatar
Quoted: 10 Post(s)
Water in Fuel
The truck will be doing fine driving along and then it start missing and sputtering and smoking. Sometimes it will go dead, sometimes Ill floor it and it will pick back up and run normal again. The "water in fuel" light came on right by the "wait to start" light, but went right back off. Im going to put some fuel treatment in it, but is there other things I can do to either remove the water or fix this problem. The previous owner says it would do it every now and then to him, but it seems to be doing it more ofter here lately to me.
2008 F250 4x4
H&S Mini Max
Diamond Eye 4 in strait pipe
S & B Intake
HIDs 6,000K
more to come hopefully soon
tblg700 is offline
post #2 of 2 Old 02-04-2013, 06:55 PM
alpinhi's Avatar
Just throwing this out, Im not a pro here by any means. I ended up with some watered down diesel last year. It took me a couple of days of driving with the treatment in the deisel to get the water out. It wasnt a immediate fix, you may also want to drain the water seperator. You may want to rethink where your buying your diesel in the future to.
Travis
96 F250 Crewcab shortbed 4x4
Tymar intake, Warn hubs, B&W Gooseneck and fifth wheel hitch, 285/75/16 Michelin A/T2's
09 Unlimited Jeep Rubicon
2" lift, 315/70/17 BFG At's, Warn 9000lb winch.
Trying to afford modifying 2 vehicles is tough!
IAFF Local 1596
alpinhi is offline
