Need help asap! What is this sensor? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 01-30-2013, 09:19 AM Thread Starter
NorcalPSD925's Avatar
I was trying to take off my fuel psi sending unit from my gauge and accidentally broke this sensor, what is it for? Truck now won't start.
96 7.3L, RCSB, Race truck
Only regular cab short bed OBS in Nor Cal!
NorcalPSD925 is offline
post #2 of 6 Old 01-30-2013, 09:26 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Re: Need help asap! What is this sensor?
On driver side?
looks like icp
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 6 Old 01-30-2013, 12:06 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
I can't see the picture (don't know if they blocked it here or its some other reason). Is it the sensor on the front of the driver's side head pointing inward at a 45* angle (the ICP)? I'll check when I get home to see if the picture works there. Cheers!
Patrick Feeley is offline
post #4 of 6 Old 01-30-2013, 12:08 PM
Looks like the icp sensor.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #5 of 6 Old 01-30-2013, 12:30 PM Thread Starter
Yeah it's the icp.. Where's a good cheap place to get it from? It's for a 96, all the ones on ebay are for 97-03.. Ford wants $190
post #6 of 6 Old 01-30-2013, 01:11 PM
jesilvas's Avatar
Quoted: 3 Post(s)
I didn't think there was a diff.
Nvmnd. Apparently it is.
Riffraff Diesel: Motorcraft ICP Sensor 94-96 - Yours
Riffraff Diesel: Motorcraft ICP Sensor 97-03 - NOT yours
4R100, 2wd
330,000 + miles
jesilvas is offline
