97 7.3 problem (VIDEO)
lastnigt going down the freeway, hit the pedal to get going, then it made some sounds and i first thought something got sucked into the turbo, but that was not it, now its running horrible, scanned for codes and came up with these
7.3 problem - YouTube 06-p1391 05-p1393 04-p0113 03-po475 02-p0478 01-p0470 looked up a few and some said it could be the injector relay, or someting related, but gotta take a closer look today. *** looking at the front of the truck, the left side (pass side) of the motor, the tube that connects to the turbo for air is popping and blow out instead of sucking in along with some smoke, broken valve? Last edited by 897.3alltheway!; 01-28-2013 at 05:03 PM. Reason: forgot info |
Clear codes and test all the fuses under the hood. Too odd that you are getting so many out of range sensors at the same time yet the truck will run at all.
it will idle, but very harsh, its obvious something wrong with it, but all those codes im not sure
