CPS Going Bad?
The other day while sitting at a light my 96psd just died like I shut off the key. Started right back up like nothing ever happened. A couple of times since then while driving, the engine bucked on me like it cut out for a split second, then ran fine. Am I correct in thinking that the CPS should be the first thing to check?
Thanks - Bill |
Yes that is exactly what it is, it should throw a SES code and light and you could read it with your tuner or go to like autozone. but thats exactly what my truck was doing when it went bad.
Thanks. Didn't throw a light, but they all happened so quickly. I'll replace the CPS just to be sure.
- Bill |
Yea yours being the OBS it might not but mine did and it threw the code, mine was actually under recall so i actually had ford replace it for me for free so i didnt have to screw with it, but like i said yours being an OBS you might not be able to get that but it doesnt hurt to try if you dont wanna do it yourself especially it being winter
Thanks. Worth a shot.
Autozone CAN'T read this truck.
Bad CPS most likely won't set a code. The PCM just interprets lack of CPS signal as the engine not turning, and does what it's supposed to do - shuts down the injectors. |
Well i wasnt sure about autozone since i have a handheld but my 2000 threw a code and also lit up the service engine soon light too and my handheld came up with an "intermittent CPS code"
