Crank and crank and crank but no start
Hello all.My truck is driving me crazy.My problem started back in August.I took my truck('97 F 250 w/7.3 powerstroke)into town.Shut it off and I couldn't get it started again.Cranked and cranked and cranked on it but no start.Had it towed into a local shop I dealt with in the past.After sitting at the shop for 3 weeks I was told it needed a new HPOP.2 weeks later I got my truck back made it 10 miles down the road shut the engine off and it would not start again.Called the shop up and they sent a guy out with a can of ether and got me going again.Since then I've changed both fuel filters,replaced the under valve cover wiring harness,replaced the glow plugs,and replaced the lift pump.Truck started fine for 3 weeks after I got it back now its doing the same thing.Crank and crank and crank and will not start Not even any white smoke coming out of exhaust.Help.
Alternator? How are your battereys?
Batteries are brand new
Back to the basics:
* WTS light coming on? * Tach movement while cranking? * Have you looked in the HPOP reservoir for the oil level? |
WTS light on, HPOP oil up,no movement of tach.
CPS or for some odd reason your PCM took a crap on you or was about to.
Most likely culprits for a no-smoke no-start situation are the #22 fuse from the fuel bowl heater touching the fuel bowl, or the cam position sensor. My money is on the Cam sensor, because in the 6 months that I've owned my Powerstroke, I've had it go out, then go out again.
If the WTS light is on, fuse #22 is good. WTS on plus no tach --> if it's not the CPS, then you can expect purple frogs to fall from the sky.
