Starts and immediately dies. - Ford Powerstroke Diesel Forum
Old 12-24-2012, 04:39 AM
My 95 powerstroke has been starting up just fine. I went to start it yesterday and it wouldn't turn over. I have a brand new starter and batteries. I sprayed some starter fluid in and it turned over, but immediately died. Any advice?
Old 12-25-2012, 05:30 AM
So is it not cranking over or not firing
Old 12-25-2012, 05:36 AM
What were the temps?
Do not spray starting fluid.
Old 12-25-2012, 06:25 PM
It was a cold start, about 30 degrees, I let the glow plugs warm up for about 10 minutes.
Sent from my DROID RAZR HD using AutoGuide.Com Free App
Old 12-25-2012, 06:26 PM
/\ +1 Don't spray starter fluid unless you deactivate your glow plugs.
Start with the simple things first. Is the Fuel Bowl full of fuel? Is your tach moving while its cranking? Is your wait to start light on before cranking?
Old 12-25-2012, 06:45 PM
glow plugs don't run 10 minutes non stop.
So it would not crank at all at first? No rotation of the crank shaft?
I made my Samsung SGH-I997 send this.
Old 12-25-2012, 07:40 PM
It was cranking, the stater was going and the fan was turning.
Old 12-25-2012, 07:42 PM
Fuel bowel is full, I have to check on the tach and the wts.
Old 12-26-2012, 07:37 AM
I'm new to working on vehicles, and I ask a lot of dumb questions, but why don't you spray starting fluid with the glow plugs in?
Old 12-26-2012, 07:48 AM
The starting fluid will go directly into the chambers which happen to have the intake valve open. The glow plugs in those chambers will immediately ignite the starting fluid. The resulting blast will blow out through those intake ports and up to the air intake. It's been known to blow up some fellas' air boxes. Thus, it is not a dumb question (it would only be dumb if you ignored the admonition....).
Starting fluid is really intended for spark-ignition (gasoline, etc.) engines, where the spark occurs (plus or minus a few degrees) right when the piston is moving from the compression to the power stroke, because it ignites so easily, even with weak spark. It does work on compression-ignition (i.e. diesel) engines, but only when allowed to stay in the chamber until the transition between the compression and power strokes.
