Oil in coolant - Ford Powerstroke Diesel Forum
Old 12-10-2012, 04:35 AM
Oil in coolant
So i noticed that there is a good amount of oil in my coolant. I did the oil cooler o-rings no to long ago but i had a heck of a time with the front bolts. I'm wondering if maybe the front cooler head to block gasket got contaminated. It does have some oil around it but while i was looking i noticed that there is some oil sludge on top of the front cover where it meets the block. So i assume i have a leaking front cover. Or maybe my head gasket is leaking out of the front? Its not the hpop or the hpop gasket. Valley does get wet with oil but I've meticulously inspected the hpop to make sure it wasn't that. If the front cover is leaking could it be contaminating the coolant?
No coolant in oil and it doesn't smell like fuel. I did order injector cups so I'm going to do those just for piece of mind.
Any thoughts guys? Anything appreciated.
Sent from my DROID RAZR because I told it to...
Old 12-11-2012, 12:39 AM
Nothing guys? Took the accessory bracket off and can tell that the oil cooler head to block isn't externally leaking. Its coming from higher. So how often do the oil cooler cores go bad?
Old 12-11-2012, 09:23 PM
i am sure had often the oil cooler goes bad. but my 7.3 had oil in the coolent and i had a brand new oil cooler put in and i havent had any more problems. i heard the seals go bad or the inside rusts out.
Old 12-12-2012, 02:09 AM
Yeah thanks, i just ordered a new core and o-ring set so we'll see. Done other people have told me that the front cover won't cause it, its pretty much just the cooler.
Old 12-12-2012, 05:15 AM
id have to guess maybe o-rings as well... post an update later
