banks turbo ? please help
hey guys ihave a 96 250 with a banks turbo on it im trying to remove it but i think im missing something.i removed 3 pedastel bolts the 4 exhaust flange nut and bolts thats all i see it will move side to side a little but thats it.all the posts i see say that there is bolts on top to remove the turbo from the pedastel but there is none there also i do not see where the oil line is going to the turbo.has anybody had this problem?please help thanks.
The bolts that would be on top are from a Super Duty 7.3L, not ours. Look to the rear of the turbo on the intake side for one more pedestal bolt. You'll need a 1/4" drive ratchet, couple of extensions, and a short socket on a wobbly. If your wobbly is too wobbly then make a couple passes with electrical tape and the tape will hold the wobbly straight but still allow the flexibility of the tool.
Did u disconect the ebv rod?
thanks alot guys i finally found that fourth bolt hidding under a bunch of caked on oil and grease.i got it out and replaced the leaking exhaust gasket and the oil seals now the fun part putting it all back together...thanks again
