Random leak... - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-25-2012, 09:25 AM Thread Starter
95Strokeee's Avatar
Random leak...
Hey everyone! I have a leak around my front driver brake, I can't tell what it is, I believe it's coolant... But i don't know how coolant is getting down to my brakes. Everything is dry except for the brakes. My brake fluid reservoir is not going down at all, but it looks like my coolant level is, just barely. This has been going on for at least 2 weeks. It only leaks after driving. Thanks. Here are some pictures Random leak...-imageuploadedbyautoguide1353867897.638429.jpgRandom leak...-imageuploadedbyautoguide1353867907.894034.jpgRandom leak...-imageuploadedbyautoguide1353867918.749242.jpg
Sent from my iPhone using AutoGuide.com App
95Strokeee is offline
post #2 of 2 Old 11-26-2012, 11:24 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
What is your brake fluid level? If it is coolant then it will smell/taste sweet (it's sugar and alcohol) but if you can get enough of it on your hand (prefurably the back) and in a couple minutes your skin feels "dry" then it is brake fluid. If it's a coolant leak the Rad. Fan _might_ be catching the drip off the water pump and flinging it over but the hood would be wet too. My money's on a bad caliper wiper seal. Remove the tire and caliper and look into the piston area.
Thanks for the pictures but the first one is too dark and the second looks like the caliper is dry.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
