cutting out at 72MPH - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-20-2012, 07:52 AM Thread Starter
while driving over 70mph the truck started cutting out like it was missing, it also died, for short time then was running again. I replaced the cps sensor back in the summer. back then it would act like it was missing then after several months it would die and not start after a long wait. replace the cps sensor and all was good. now i cant go over 70 and it will act up. any ideas?
bassman11 is offline
post #2 of 4 Old 11-20-2012, 09:17 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
What is your high pressure oil line pressure? What is your fuel pressure?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 4 Old 11-20-2012, 09:39 AM Thread Starter
Bigfuel not sure how to check that, my guages look good but i dont think that is what your referring to.
post #4 of 4 Old 11-20-2012, 11:13 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Checking fuel pressure is easiest. Ideally you need one of these (Summit Racing® Chrome Plated Fuel Pressure Gauges SUM-800199 - SummitRacing.com what ever one you buy does't really matter but it needs to be fluid filled to stabilize the needle) and a 1/8"-1/8" NPT female coupler. On the back of the fuel bowl there is a Schrader Valve. Spin out the valve from the port and install the coupler and gauge. This will get you idling and neutral rev'ed fuel pressure but if you install an 1/4" rubber line rated to 100 psi and Diesel you can run the line to your windshield wiper and watch the Fuel pressure as you drive.
For the HPOP oil galleys get a gauge rated for oil and 3000 psi. have your local hose-man or tracktor shop make you a line that will come off the oil galley in the head (I think that it's 1/4" NPT for the hose) and do the same thing. Run it to your windshield wire and watch it as you drive.
An expensive auto scanner will be able to monitor the HPOP but those are big bucks.
Matt
'97
-Stage II trans.
BigFuel is offline
