Air pump pulley question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-15-2012, 12:18 PM Thread Starter
Should this pulley feel like it has a some tension in one spot but nothing on the other, like its oblonged in a spot, I'm assuming its to do with the pump, just concerned!
Evanla_33 is offline
post #2 of 4 Old 11-15-2012, 02:15 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Take the belt loose and grab the pulley to see if the bearing is going out. It should ride pretty flat on the belt.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 4 Old 11-15-2012, 03:46 PM Thread Starter
It does feel tight but when u spin it,its not like a regular idler, i'm assuming it has to do with the pump but i'm not a 100%, just wonder if it should spin like a regular idler. Or is it messed up but it doesn't have any play back and forth. Just wondering if it need to be replaced
post #4 of 4 Old 11-15-2012, 04:06 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Naw, it has a "lope-y" rotation. The insides are like a inline two cylinder piston pump. This is what builds the vacuum pressure.
Matt
'97
-Stage II trans.
BigFuel is offline
