Water pump... Looks like leak from weep hole .
So I'm thinking I have to replace my water pump. Looks like a pretty easy straight forward job. Watched all the Poerstrokehelp videos but it was on a 99-02 7.3... Any difference between engines in this department?
What water pump should I buy, I see them form $100 - $300 .... cheaper price would be best.
Do you guys know if they come as a kit with all the hardware and gaskets.?
While I'm in there is there anything else I should change?
Can I only get certain parts from ford?
How much coolant do I need and do you know the name of the additive I should use?
Thanks guy, it its not one thing, it's another.
