cranks but no start
replace cps, fuel filter about a week old . Dont now to much but I tryed the basics any one out there that can point me in the right direction need help
* Is the WTS light coming on?
* Does the tach move? * Any white smoke? |
yes the WTS light comes on
the tach moves when its cranking and no smoke @ all |
yes WTS light comes on
thach moves as it cranks and no white smoke |
May look into getting a scanner on it while cranking to confirm it's making ICP, it will need 500+ ICP to fire and run. If it's not, I'd check the ICP sensor, IPR, and High Pressure Oil Pump. Also go through and check all your fuses to ensure they're all in good shape.
Also swap your #2 and #3 relays.
did swap relays and nothing
sorry but my english not to good whats the IPC sensor and where is it located and the IPR love the truck but dont now much about it where can i get a scanner and what would be the price$$
disconected the lines going to the heads and getting oil my HPOP resivor is full
Notice some oil in the valley does this means the o rings in the pop are bad. An will this cause it no to start. It was a about 2 qts low. But added some oil. Just cranksno start
Sent from my HTC One X using AutoGuide.Com Free App |
