Coolant Leak - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-11-2012, 05:58 AM Thread Starter
PSDTV21's Avatar
Coolant Leak
Changed coolant yesterday. After pouring in coolant checked for leaks and there were none. Started it up took it for a drive to warm it up. After i shut it off and it cooled down i noticed a leak. Took a look and it appears to be coming from a hole in the water pump under the pulley. Is there supposed to a plug there of is it time for a new water pump?
-Tyler
1994.5
Efuel, Valair 500hp, D60, Hydra w/PHP tunes
PSDTV21 is offline
post #2 of 3 Old 10-11-2012, 07:47 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Time for a new water pump (that's the weep hole to tell you the pump is done). Cheers!
Patrick Feeley is offline
post #3 of 3 Old 10-11-2012, 07:59 AM Thread Starter
PSDTV21's Avatar
Thanks for the help.
-Tyler
1994.5
PSDTV21 is offline
