Replaced fuel filter today, engine repeatedly dieing - Ford Powerstroke Diesel Forum
Old 10-10-2012, 05:01 PM
Hey guys,
I just replaced my fuel filter today with one of the Motorcraft filters after I got the fuel filter light on the dash and the engine died a few miles from home. After driving about 10 miles today the same issue arose again. I haven't pulled the filter yet to look at it but the filter light was remained on even after it first started running with the new one in. It idled fine with no fluctuation in the rpm's... Any suggestions?
Old 10-10-2012, 05:23 PM
drain the housing
Old 10-11-2012, 05:44 AM
Agreed sounds like fuel/water sep needs draining. Clean the FPR screen also.
Old 10-11-2012, 07:45 AM
What's the fuel pressure when idling? Have you tried switching tanks? Cheers!
Old 10-11-2012, 03:32 PM
When I popped the housing open today I noticed that there was a really low level of diesel in there. I drained the remaining diesel left in fuel bowl and pulled out the screen on the FPR. The screen was clean and with the bowl drained I figured I would just check to see if it would fill when the key was put in the run position. I didn't hear the fuel pump kick on and after a few times of cycling it the bowl never filled, so I'm guessing the lift pump has gone. Bummer!
Old 10-11-2012, 04:06 PM
the pump is mechanical not electric in an obs
Old 10-11-2012, 04:31 PM
De-rail in 3... 2... 1...
With the engine idling push the schrader valve to let the excessive air out of the bowl. Top rear of the bowl.
Old 10-12-2012, 05:17 AM
What he said. No LP.
Tags
filter, fuel
