injector swap, no start - Ford Powerstroke Diesel Forum
Old 10-10-2012, 01:46 AM
Ok pulled all my injectors yesterday, cleaned all the oil outta the cylinders by bumping the motor with the glow pulgs out, replaced all my injectors, orings, R/H valve cover gasket and all glow-plugs. Now motor cranks kinda fast for a min, the kicks once or three times, then cranks slow and SPEWS smoke outta the stacks but wont fire. What could I have missed? Harness is all plugged in, HPOP res is full, New fuel filter, about 40PSI at the schader valve on the fuel bowl while cranking.
Old 10-10-2012, 04:10 AM
There may still be air in the oil rails. It takes a while to purge the air out after an injector change. Keep trying in short bursts, letting the starter cool. Cheers!
Old 10-10-2012, 07:31 AM
Ok UPDATE!!!! After 12 hours of cranking (hopefully saving the starter) I figured out that my batteries are weak, swapped out for a set of brand new EXIDEs and cranked for a couple of cycles and up she fired!!! Had her running on high idle for 30 min now to warm her up and heading out for a drive! Will post back with a follow-up upon my return.
Old 10-11-2012, 04:34 PM
Ok love the new sticks!! Also did the turbo swap today , this thing is awsome im making boost at 1300 RPMs now!! I even accidentally smoked my rear tires to!! Gonna tackle the HPOP on Sunday after a family putting this weekend!! Will keep ya posted!!
Old 10-12-2012, 11:28 AM
What kind of turbo did you get??
Old 10-12-2012, 12:54 PM
I believe he just got the 1.0 housing for the stock turbo
Old 10-12-2012, 03:27 PM
I got a "HIGH PERFORMANCE TP-38 Powerstroke turbocharger with BANKS 1.00 QUICK SPOOL turbine housing and new BANKS compressor wheel. " from Ron's turbo in SLC.
