Unknown leak. Need help. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-02-2012, 01:42 PM Thread Starter
jdreswick's Avatar
Unhappy Unknown leak. Need help.
Today i looked under my hood and there seemed to be something sprayed on the air intake side of the engine. At first I thought it was brake fluid but after closer examination I noticed it was what looked to be grease with metal shavings in it. It looked to be coming from the powersteering pump. But I am not sure. I was wondering if you guys could help.
(new truck)1983 f250 ext cab 6.9 n/a 4spd no rust
(gone)1995 F250 extCab
k&n filter, Kelderman air ride
jdreswick is offline
post #2 of 3 Old 10-03-2012, 05:51 AM Thread Starter
jdreswick's Avatar
Found out it was the vacum pump.
post #3 of 3 Old 10-11-2012, 04:49 PM
PoppaSmurff's Avatar
Ya mine just failed but didn't give warning like that! Just flew apart!
'95 7.3 crew cab, Dyna 60 fnt/60 rear
E4OD Auto Slush-box
6 Pos. TS chip,
3" turbo oulet/down pipe,
twin 5" stacks,
custom 1/4" plate winch bumper
w/12000lb Hyd. winch,
3 guage A piller cluster,
Banks 1.00 turbine houseing and compressor wheel,
T-500 HPOP,
DIY 50+HP injectors,
High Pressure Oil X-Flow line,
Hadley air horns and air comp.
PoppaSmurff is offline
