diesel fuel is in coolant resorvoir - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-23-2012, 06:01 PM Thread Starter
dieselwezel's Avatar
major issue,today parked truck and smelled alot of diesel..coolant overflow was full of diesel and overflowed with pressurized fuel. How can diesel and coolant mix? Engine oil is fine. Could this be o rings on the injectors? I am at a loss with this one on how to properly diagnos.
Thanks for any help in advance!
1997 F-350 4x4
Flowmaster DP
Superchips max tuner...makes a good code reader
SD IC
DIY 6637
TW 6-pos
dieselwezel is offline
post #2 of 13 Old 09-23-2012, 06:09 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Injector cups usually I think.
When it's that issue it's a fairly common theme.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 13 Old 09-23-2012, 06:20 PM Thread Starter
thanks,these cups remain in the head when the injectors are removed?
1997 F-350 4x4
Flowmaster DP
SD IC
DIY 6637
TW 6-pos
post #4 of 13 Old 09-23-2012, 06:25 PM
FreightShaker244's Avatar
Sounds like injector cups!! When you pull injector out they remain in head still. They do require special tool to pull them out.
1995 F-250 7.3 Powerstroke 5 Speed, 6'' Lift. DIY Intake/Napa filter, 4" exhaust.
FreightShaker244 is offline
post #5 of 13 Old 09-23-2012, 07:23 PM Thread Starter
just on my mobile here so to do my homework with this is abit of a struggle..so the cups is what needs replaced..i am looking thru my chilton diesel repair and they mention 'injector sleeves' which are inside the injector bore. Question, are these the 'cups'? Just another name
1997 F-350 4x4
Flowmaster DP
SD IC
DIY 6637
TW 6-pos
post #6 of 13 Old 09-23-2012, 07:29 PM
Only thing inside the injector bore.. Hole where injector goes.. Is a brass "cup" at the bottom... Ie injector cup. So sounds like same thing
post #7 of 13 Old 09-24-2012, 09:39 AM Thread Starter
i am having a hard time with the dealer to simply ask for 'injector cups' or even sleeves.
Is there any chance these are available aftermarket? If so who would carry these? I can source the o rings but stumped with the cups.. Also if somebody can post a link to what these actually look like would be great.
I just dont want to remove a valve cover until i know what i am getting into.
Thanks,
~Bruce~
1997 F-350 4x4
Flowmaster DP
SD IC
DIY 6637
TW 6-pos
post #8 of 13 Old 09-24-2012, 09:45 AM
FUEL INJECTOR CUP SLEEVE 7.3 FORD POWERSTROKE DIESEL | eBay
'03 F350 7.3l auto crew cab dually, 'n stuff.
Demian1970 is offline
post #9 of 13 Old 09-24-2012, 09:46 AM
Even better....
7.3L 7.3 FORD POWERSTROKE INJECTOR SLEEVE CUP REMOVAL TOOL & INSTALL KIT | eBay
post #10 of 13 Old 09-24-2012, 10:13 AM Thread Starter
Awesome,thanks for that! This i believe is the way to go.
Ford quoted me 45 dollars just for each sleeve!!
1997 F-350 4x4
Flowmaster DP
SD IC
DIY 6637
TW 6-pos
