up pipes
is there a permanent fix or semi permanent fix for up pipe leaks ? I get it fixed lasts a couple of months , rather expensive at 5 to 7 hundred bucks a pop.
any after markrt pipe kits ? 95 350 duelly RV puller . |
The best fix is the International bellowed uppipe kit (doesn't use the stupid donuts). It is rather expensive for the OBS trucks at about $800. Some folks have massaged (slightly expanded) the uppipes so the donuts fit a bit tighter or used the brass donuts that are (were) available from Beans Diesel Performance (BDP) with varying degrees of success. Cheers!
