96 Powerstroke died while driving
Long story, but I bought a 96 7.3 with a 5 speed about two hours ago. Took it for a long test drive, no problems. Bought it, got five miles down the road and it just died. At 60mph the motor just stopped running. When i got to the side of the road, the motor cranked really strong, there's fuel in the bowl and I even tried unhooking the chip. No dice. Luckily, the seller was a stand up guy and came out and gave me my money back. I told him that if he figures out what the problem is I'd still consider buying it.
7.3 with 243k but the motor was completely rebuilt 3000 miles ago. No throttle response when it was cranking with ether. Any idea on what could possibly be wrong with it? I think its something electronic, maybe the ECM or CPS. Thanks guys, any help would be much appreciated.
Was the tach moving when you were cranking it?
Did the CEL come on? |
The tach was moving. CEL was on and off. Came on when it died and sometimes while it was cranking but not starting. We got some ether and sprayed it and it weakly ran while it was being sprayed. Even ran weakly under its own power but would't stay on. No throttle response whatsoever.
Why would there be throttle response in a dbw heui injected truck? There wont be any. More info would be helpful. What were you doing when it died. Did you test drive the truck before buying? What were the gauges doing when it died? Is there diesel in the tank (without trusting the gauge)? Quote:
I'd try a cps, cheap and easy before delving into anything else.
unplug the fuel bowl heater, any blown fuses in the distribution box under the hood.
^Good one. If the bowl heater grounds out then the truck wont start and gets real pissy. I'm curious to know what cps it's using and when it was replaced also. |
