95 no start still - Ford Powerstroke Diesel Forum
Old 08-21-2012, 10:10 AM
95 no start still
ok so trying to start still. cranks like a champ but wont turn over. i have plenty of oil in pan and in hpop resivoir. fuel pressure and oil pressure at the head. glow plugs are working. unplugged ipr and icp. replaced cps. tach moves. wts on no cel. tested wires from harness to idm all test good. harness all connected. ive been thinking idm.
i got t oreading the ol haynes manual and it gave this idea
no fuel to cylinders: remove a glow plug depress throttle slightly and crank the engine for five seconds ino fuel vapors come out of the glow plug hole go to step e.(plugged fuel return system) if fuel vapors come out remove the rest of the glow plugs and see if fuel vapor comes out of each hole when the engine is cranked if fuel comes out of just one hole clean and test the injection nozzle for that cylinder. crank the engine and note whether fuel vapor is coming out of every glow plug hole. if fuel vapor is coming from every cylinder go to step k( incorrect or contaminated fuel)
so i have vapor coing from every glow plug hole. my thought process is then that each injector is injecting which means the idm is working am i correct here?
so it tells me my next step is k incorrect or contaminated fuel. is there a way to check that with out draining it all and adding new.
any other thoughts or things i should try would be much appreciated
Old 08-23-2012, 09:08 AM
De-rail in 3... 2... 1...
Have you been helped?
Old 08-23-2012, 09:14 AM
nope not yet.
Old 08-23-2012, 09:21 AM
Ok, so you can crank the motor but no white smoke out the exhaust? Check fuse 22 under the hood. Middle row farthest from you. IF it has popped don't throw a new one in till you check the wiring on the fuel heater on the fuel bowl.If the fuse is good then swap the #1 and #2 relays.
Old 08-23-2012, 09:22 AM
Sorry, the #1 and #3 relays.
Old 08-23-2012, 09:27 AM
so when the truck first died the #22 was blown replaced it and blew again so i removed the fuel bowl heater now it doesnt pop. but still no start. ive switched around the relays in like a million different combinations ive thought of just buying all new ones though
Old 08-23-2012, 09:32 AM
Fuse 12 still good? Well all other fuses still good?
Old 08-23-2012, 09:37 AM
Yep all the fuses are good I should have specified that sorry
Old 08-23-2012, 10:32 AM
check your fuel filter for oil, check fuel pressure
Old 08-23-2012, 10:38 AM
as far as i can tell no oil in fuel bowl and plenty of pressure at the schrader valve
