95 f350 oil in turbo
Hey guys i just bought a 95 f350 it white smokes like crazy i looked at the turbo and i have oil in the turbo is that normal or what
Which side of the turbo? Compressor side (aluminum) or turbine side (iron). No the Turbo should be dry I'm just asking for the side to see what direction to steer you.
its the compressor side
Take the rubber tube off the turbo (intake tube between the plastic "support" and the compressor. Is there oil in it?
The CCV system usually makes a nice oily mess of the intake/compressor. But if it smokes like crazy, that seems a little off...
Yes there is and how do you fix that
F-it. Turn the CCV around and run a 1/2" hose rated for oil off the engine, down the side, and out the back of the cab. I think the support is 4" OD. replace it with a piece of exhaust tubing. Or, I bought this:
DFUSER Diesel Performance Products Exhaust High Performance Part Diesel Intake Diesel Power Chips
