1996 7.3 glowplug problems - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-18-2012, 07:51 AM Thread Starter
strokin95style's Avatar
OK, based of the info I have got from my father in a state away, he is re o-ringing the injectors on his dads truck. Not sure which cylinder it was but one of the glow plugs was seized into the head. He mentioned that the glow plug spun forever but would not back out. Come to find out, he said the glow plug separated in two. The cap for it came off. How do we go about getting the bottom half out? Thanks in advance guys
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #2 of 5 Old 08-18-2012, 11:26 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
You change your avatar? A magnet and a lot of beer.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 5 Old 08-19-2012, 04:27 AM
jimdritru's Avatar
Start spraying glow plug that is stuck with PB Blaster. Sometimes if you crank over engine the compression will shoot it out- WARNING! Put a piece of plywood over it because it will come out like a bullet. If that doesn't work use needle nose pliers and vice grips to grab onto plug and start wiggling and twisting it to break it free. I also used a long 1/4 drive extension and tapped lightly on the plug to break it free. PATIENCE is your friend. This isn't a 5 minute job. I had 1 fall down onto the piston. I got it out by going through the injector hole with a pocket magnet.
97 F250
Straight pipe, DIY intake, Timbrens
jimdritru is offline
post #4 of 5 Old 08-19-2012, 07:42 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 40 Post(s)
Oops, I was thinking that you ment that the part the sits inside the cylinder came off the assembly and fell into the cylinder.
Matt
'97
-Stage II trans.
BigFuel is offline
post #5 of 5 Old 08-19-2012, 07:45 AM Thread Starter
Yeah, I got bored. My grandfather got it out, not sure how he did but I'll post it when I find out.
Nater
1995 f-250 rclb
3" Downpipe
Dana 60 s.a.s
