Dirty injectors - Ford Powerstroke Diesel Forum
Old 08-13-2012, 03:47 PM
Dirty injectors
Ive had a stuttering problem on my truck for a while even after changing the hpop, uvch's, icp, ipr, fuel pump, fuel bowl orings and lines. Finally decided to pull the injectors and change the orings and this is what i found.
Sent from my DROID X2 using AutoGuide.Com Free App
Old 08-14-2012, 08:38 AM
De-rail in 3... 2... 1...
Hmm...lots of people looking but no reply's. That cylinder has a oil leak (I know, you knew that). What cylinder is it? Engine oil and coolant smell free of diesel?
Old 08-14-2012, 09:15 AM
Ive only taken the passenger side injectors out yet but every cylinder looked like this. I think the orings were week then when i put a 17* hpop and tuner in it finished them off. Im changing all the orings and cleaning them up.
Old 08-14-2012, 09:16 AM
Old 08-14-2012, 01:17 PM
Check the turbo for an oil leak while your in there. Just to make sure that it's not coming from there also.
Old 08-17-2012, 09:11 AM
I got em all back in and fired up, just to find 2 injectors not firing! Dont know why i didnt check before I took them out. I've got a set of ad's on the way.
Old 08-17-2012, 09:15 AM
It's the frustrations in live that let you know that you're still living it. Are the injectors next to each other?
Old 08-17-2012, 09:24 AM
Nope, #4 & #7
Old 08-17-2012, 09:28 AM
Are you... all back together? Moving injectors would tell you straight out if the problem was the injector or the electrical.
Old 08-17-2012, 09:51 AM
Yeah, but honestly i dont want to go back through purging the cylinders and ive already got a set on the way. But if 4&7 still dont work with the new ones ill know for sure.
